08-13-2009 10:33 AM
I would like to obtain the mean average of the last 200 data-points (sampled at 100Hz), and publish the running average at 10Hz.
My preferred solution is modeled on the RT FIFO that is available from within the LabVIEW Real Time module. I plan to have 4 VI's as follows:
1) "Averaging FIFO Create.vi"
Description: this VI will have similar functionality to: RT FIFO Create.
Inputs: String name, Int32 size, Boolean create if not found, Error Cluster error in
Outputs: Refnum fifo, Error Cluster error out
2) "Averaging FIFO Write.vi"
Description: this VI will have similar functionality to: RT FIFO Write.
Inputs: Refnum fifo, Single element, Error Cluster error in
3) "Averaging FIFO Read.vi"
Description: this VI calculates the mean average from the specified number of elements
Input: Refnum fifo, Int32 number of elements, Error Cluster error in
Outputs: Refnum fifo, Single average, Error Cluster error out
4) "Averaging FIFO Delete.vi"
Description: this VI has similar functionality to RT FIFO Delete.
Inputs: Refnum fifo, Error Cluster error in
Outputs: Error Cluster error out
Unfortunately, I do not know how to implement the solution in LabVIEW.
Is the LabVIEW RT FIFO, implemented in LabVIEW or C?
I am not sure if it is possble to obtain the required functionality (e.g. dynamic memory allocation) in LabVIEW?
Then again, maybe it can be done in some other way?
How do I create the FIFO object/cluster and store it in memory? I also need a reference to the stored object/cluster.
Do I need to use LVOOP?, and if so can I hide the OOP from the user? e.g. by implementing the four VI's in a library?
Please advise.
Mark
08-13-2009 10:39 AM
Thats a funny question. LabVIEW of course!
For FIFO functionality, you should take a look at 'lossy queues'. You can allocate a certain size for the queue, then use 'lossy enqueue'. This will exactly replicate the FIFO functionality you are looking for.
All you would need is a top level VI. Make the other 4 VI's you mentioned subVI's and call them in the top level VI. You can move this FIFO queue from subVI to subVI no problem.
08-13-2009 11:25 AM
For "Averaging FIFO Read.vi", I need to average all elements in the FIFO with-out dequeing any data.
I need a lossy FIFO/queue, just like RT-FIFO. But unfortunately, you can not read the data in an RT FIFO without removing it.
This is why I need to have my own implementation of a FIFO, rather than use the LabVIEW built in functions.
At a lower level, I (think) LabVIEW built in functions are actually written in C?
I am not sure whether it is possible to obtain the functionality of a LabVIEW RT-FIFO by using only LabVIEW itself?
To create a FIFO (with create if not found input) I will need some form of dynamic memory allocation and management.
Is there are a way to do this in LabVIEW RT?
Mark
08-13-2009 11:49 AM
Well I recommended queues, but if you need to operate on elements without dequeuing them,
you could use an array. Its slower, but it works.
The averaging would be pretty easy:
You would just need to find an efficient way to make the array FIFO.
Hmmm, let me think of an efficient solution to this, I will let you know if I come up with something.
08-14-2009 03:17 AM
Thanks Cory, but that's obvious and does not solve my problem.
Is there any way to do this in LabVIEW RT?
The problem is, how to create the FIFO's (object/cluster) by name, and store/manage them in a dynamic list. I will need to Create the refnum/reference to the FIFO, so that it can be passed to the Read, Write and Delete VI's.
I could insert a new cluster into an array of FIFO (object/cluster), but then I do not have a refnum because I can not create one programmatically.
