How to link my access database to ODBC?
srinivasan.accent@gmail.com wrote:
hi,
 same program is in example program of labview 8.6 evaluation.. but its working correctly.. but i verified the example program with my program.. the method of creating of new table name in automatically is same but its not working in labview 7.0.... u can clear my doubt.. Smiley Indifferent
No!
Rolf Kalbermatter
My Blog
Message 31 of 40
(1,401 Views)
i dont know why responsing me so hard.. i didnt ask any wrong question....ok thank you for ur help....Smiley Tongue
N. Srinivasan
Message 32 of 40
(1,396 Views)
here is the error code description...
N. Srinivasan
Message 33 of 40
(1,384 Views)
hi,
here see this error occurences..
N. Srinivasan
Message 34 of 40
(1,383 Views)
So it says that there was a syntax error in the creation of the table and from your frontpanel it is visible that you use column names with spaces. Try to remove those spaces or replace them with an underscore and see what happens.
Message Edited by rolfk on 10-27-2009 11:44 AM
Rolf Kalbermatter
My Blog
Message 35 of 40
(1,378 Views)
hi rolfk,
 As u told to do goolging for this error.. i studied about this error due to some space in the file path of the .UDL....
but i didnt try to change the space in the column name.. now i change the column as Pin1,pin2,...... instead of pin 1, pin 2 ...
now its working correctly..
Thank you very much...Smiley Happy
N. Srinivasan
Message 36 of 40
(1,369 Views)
hi,
And please next time create a real JPG or PNG image and not a Windows Bitmap disguised as JPEG. They are unwieldy large and slow to download.
Rolf Kalbermatter
My Blog
Message 37 of 40
(1,368 Views)
OK SURE....
N. Srinivasan
Message 38 of 40
(1,353 Views)
OK SURE.... ROLFK
N. Srinivasan
Message 39 of 40
(1,353 Views)
Great example Mike. It helped me a lot in modifying my .udl file so that it would be readable by the database toolkit again.
Thanks. Smiley Happy
Preben
Message 40 of 40
(1,032 Views)
