How to load a VI into a dynamically selected SubPanel?
I would like to dynamically select a subpanel for which to load a VI into.  I modified the LabVIEW Help example "Multiple VIs in a Subpanel.vi" to illustrate my issue.
I understand the static example.  It works fine.
I have a situation where I have several subpanels and a number of Plugin VIs.  Here is an example of how I thought I might be able to code it.  What is wrong?  I understand this may be pushing scripting a little bit too far.
A fall back is to use explicit instead of the implicit Insert VI Method.  But that is not as elegant of code and not as scalable.
Mark | CLA
(1,013 Views)
Accepted by Mark_L
Your code has the VI trying to edit itself.  Which is not allowed.
The "Create.Control Ref" method creates a reference on the block diagram of the VI that owns the SubPanel (which is itself).
Try the attached VI instead.
(973 Views)
Your example VI works.
I understand now and I thank you for your explanation.
Mark | CLA
(927 Views)
