How to make the search 1D array function case insensitive for string array
Message 1 of 13
(5,528 Views)
Accepted by Flamboyant
Hi cooldude,
convert both (array and search string) to lowercase before using this function...
Message 2 of 13
(5,513 Views)
Why are you using Search Array-Functions for strings when there are several Search String-Functions?
And can you please explain it a bit more in detail?
Message 3 of 13
(5,512 Views)
Agreed. For example Match Regular Expression has an input for ignore case.
Richard
Message 4 of 13
(5,506 Views)
Well, the user did say they have a string array, so....
Of course, they could use the Array to Spreadsheet String so then they could use the string search functions, but that would embed undesired characters in the string since the Array to Spreadsheet String does not accept an empty string as a delimiter.
Message 5 of 13
(5,491 Views)
I assumed the user would throw the function into a for loop. For that matter, you still have to use a for loop with "Search 1D Array" if you want to return all elements found (or use OpenG's Search Array which functions like a "Search Array Until Done").
Message Edited by Broken Arrow on 12-01-2009 09:31 AM
Richard
Message 6 of 13
(5,482 Views)
In my post above, I should of said while loop where I said for loop. (for loop would work but while loop would be more conventional).
Richard
Message 7 of 13
(5,472 Views)
Well, a substitute for the nonexistent "delimiter-free array to spreadsheet string" is a simple "concatenate strings" of size=1. Try it!
Still, since strings are variable lenght, we would lose all information on index position, so this method would only partially work for simple questions such as "s there a match". It can also give false positives, e.g. if the search string matched the tail of one string concatenated with the head of the next element.
If all the OP is looking for is a case insensitive match of an entire array element, I would go with Gerd's suggestion above.
Message 8 of 13
(5,462 Views)
Yeah, I know about this. I was just making a point about the fact that the source is an array, and not a string.
And I was taking a pot-shot at NI over that function. Smiley Very Happy
Message 9 of 13
(5,459 Views)
Me too! 😄
Message 10 of 13
(5,455 Views)
