How to match RGB images using match multiple geometric patterns
Good day! I'm trying to match eye colors using match multiple geometric patterns but I can't do it since the output in match multiple geometric pattern is in black and white. Is there a way wherein I can change the output to RGB instead of black and white? Thank you!
(6,022 Views)
Usually pattern matching starts with converting RGB to greyscale!  Color adds several additional dimensions to the problem.
(6,000 Views)
I changed the vision info to "color template", but there's an error with its template. How am I going to fix it? Also, attached below is the output image of the load button, how can I change its palette to RGB? Thank you.
(5,979 Views)
What is the error you are getting?
(5,958 Views)
I think it is similar post here: http://forums.ni.com/t5/LabVIEW/Is-it-possible-to-match-multiple-color-patterns/m-p/3339603
-Geometric pattern works on gray scale images(what you told black and white)
-Color pattern matching works on Color image(e.g., RGB)
Be clear what you want to do
-You want to do Geometric matching then the input and output will be grayscale: http://www.ni.com/example/30535/en/
-If you want to do Color pattern matching check this example: http://www.ni.com/example/30548/en/
-Each type of template carries different information so you cannot mix and use.
-You can learn more on Color Pattern matching here: http://zone.ni.com/reference/en-XX/help/370281AC-01/nivisionconcepts/color_pattern_matching/
uday
(5,953 Views)
study this link it could help you could no use GM for color match
http://zone.ni.com/reference/en-XX/help/372916L-01/nivisionconcepts/color_classification/
(5,942 Views)
