How to read bits from the file?
Hello everybody,
I'm beginner in LabVIEW. I need to get bits from the file, but I don't know how I can do it. I use the example "Read Binary File VI" from LabVIEW Help, but it returns DBL array. And for a long time I can't find a solution to convert this array to array of bits. Cat Sad  Can somebody help me? Thanks in advance.
(2,853 Views)
Accepted by topic author tranonim
This is a very vague question. A file is nothing more than a long string of bits, so you could simply read it as a string and parse out the bits the way you want them. I don't know how you want them 🙂
One possibility would be to cast to an array of U8, then use "number to boolean array" in an autoindexing FOR loop, followed by reshaping to a 1D boolean array. You could also format the U8 as %08b and concatenate the strings. There is no "official" way to represent "bits" to the human observer. 😉
(2,837 Views)
@tranonim wrote:
Hello everybody,
You can pass in the type into the Read Binary File VI to get the data in whatever form you want.  Just remember that a boolean is really 8 bits.
GCentral
(2,830 Views)
Thanks guys! Special for
(2,796 Views)
