How to read sample rate from a .txt file
Accepted by topic author Bebeto
Bebeto,
I believe my initial guess was correct.  I am unable to completely test, as I am missing the toolkits and subVIs, but the problem was that you didnt have the shift register wired to the case output tunnel in all of your cases.  So, you would populate the shift register in the LOAD case, but then if the code executed any other command from the state machine, the shift register would be cleared back to its default value.  I assumed you were running 8.6.1, so I saved the modifed VI and have attached it here.  Let me know if you have any questions.
My company also specializes in NVH applications, so let me know if there might be something we can do for you.
John Niezgoski
Signal.X Technologies, LLC
www.signalxtech.com
Message 11 of 13
(660 Views)
Thanks a lot John,  and I will keep in mind your company, again thank!
LabVIEW Intermediate I level!
Message 12 of 13
(648 Views)
Bebeto,
No problem.  I am glad I could help.  Thanks.
John Niezgoski
www.signalxtech.com
Message 13 of 13
(646 Views)
