How to save string in a file with special-chars
i´m usingthe MD5-llb to create a password.
Then i  want to save this MD5-string to a file and later read it back abd compare.
Works perfect with one proplem:
Some word create a "\r" in the MD5-string and when i save this string to a file and read it back then its read back as a "\n" so that the compare is not working.
My question is: How can i save a string exactly like it is to somewhere and read it back (also invisible chars)
For example the word: heinz
is in MD5: \r\FB^\07\A6\07T\C7\D9\C2\94\AB\C9\1DS\95 (string indicator as codes display)
when i save the string to a file then i rerad back: \n\FB^\07\A6\07T\C7\D9\C2\94\AB\C9\1DS\95
I used the "write text file" and "read text file"
What do i have to use to save and read the same?
Thx
Message 1 of 9
(2,918 Views)
I believe an MD5 hash is 16 bytes long. Use the binary read and write file I/O functions and specify the length of the data to be read or written.
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
Message 2 of 9
(2,913 Views)
Seems to work.
Now i read back \00\00\00\10\r\FB^\07\A6\07T\C7\D9\C2\94\AB\C9\1DS\95
The question is only why there are 4 bytes offset? The first 4 bytes are always 00 00 00 10?
What does this mean?
Message 3 of 9
(2,907 Views)
Accepted by OnlyOne
Have you tried right clicking and unselecting 'Convert EOL'?
Message 4 of 9
(2,905 Views)
The 10 (16 in decimal) is the string length. Set the input "prepend array or string size" to FALSE.
Message 5 of 9
(2,903 Views)
Hi Dennis,
this solved my problem. Thx for the tipp
Message 6 of 9
(2,892 Views)
Hi dan_u,
thx for the information. But i dont have an input "prepend array or string size".
Message 7 of 9
(2,889 Views)
In the binary write function this input exists. In the text function of course it doesn't.
Message 8 of 9
(2,865 Views)
Hm, now at the second look there is the input.
I dont know where i looked before.
Thx for the help
Message 9 of 9
(2,863 Views)
