How to set limit function,means I want to set one logic that when value is between 0 to 0,3 then loop will stop.
I am looking for logic that how to set logic for upper limit and lower limit.
Means there is one input indicator in which user can enter any value, I want that when user give value between for example 0 to 0.3 then while loop will stop other wise it will run continuously.
Please guide me.
Thank you very much.
(2,551 Views)
I tried with this attached simple vi. But in that case when limit exceed 0.3 then vi is working good means its run continuously but when I enter some negative value or less then 0 value then it should be run continuous because its not correct value, but it can't.
I want that when value is between 0 to 0.3 then its stop the while loop otherwise it should be run continuously.
Please guide me some idea regarding to this that how can I solve it.
(2,543 Views)
I got solved..... Hopefully
I have to check with the system and if i have any problem then i will post it here again.
thank you very much....
(2,538 Views)
Accepted by topic author AnkitRamani
Please consider the VI below.
Smiley Happy
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(2,527 Views)
