08-03-2010 01:42 PM
Hi all,
I have two very differnt USB boards the NI USB 6008, which I am using to acquire the data (Analog Input) and a NI USB 9263, it is an Analog Output only board that I am using to deliver a signal (in this case a square pulse). The reason why I am not using the 6008 Analog Ouputs is because I need to deliver negative voltages and need the full +/-10V range.
Looking at similar posts I am pretty sure that I can't use an external trigger or a shared clock, I also tried to use the synchronization of timed structures but no cigar.
I am including a quick vi that I whipped out showing how the signal jitters due to the lack of synchronization. The AO from the 9263 connects to the AI in the 6008 in this example.
08-03-2010 04:26 PM
I talked to a specialist in the phone and tols me that it is not possible. 😞
