How to turn on the LED when a threshold is reached and turn off only when the value doesn't reach the threshold for a certian time?
Hi, I want to write a program that can light up the LED when a value reach it's threshold, and only when the value doesn't reach the threshold for a certain time, let's say 5 second, then the LED will turn off,otherwise it will remain. How can I achieve this in labview?Can someone help me? Really thanks !
(3,016 Views)
Accepted by winnie11
I guess you're using a while loop to keep the value updated.
Add a shift register to your while loop initialise it with a U32 (time in ms)
Add shift register to your while loop which keeps the previous value of your bool
WHen your value reaches the treshold => turn light on and put current time into your shift register.
In the next iteration of your loop check wether value is still above treshold
=> Y => was previous value true?
    => Y => next iteration
    => N => turn light on and put current time into your shift register.
=> N => substract current time minus time in shift register => bigger then 5 secs?
    => Y =>  Keep light on
    => N => turn light of
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,012 Views)
Oh,I think I understand what you mean.I will try it,thank you!
(2,996 Views)
