11-14-2007 09:18 PM
11-14-2007 09:59 PM - edited 11-14-2007 09:59 PM
Hi Meenatchi,
By two screens you mean two front panels right ? If so and both are part of the same program then you may consider using global variable. You can keep reading the global variable where ever you want to display the datas while updating the variable where the data is captured/obtained.
Hope it helps
