08-17-2005 01:04 AM
Hi, dear all,
I am looking for a method to send 10-bit word data to AD8403 Digital Potentiometer from PC’s Serial/Parallel Port or DAQ card.
Is it possible to implement such a communication with LabVIEW?
Are thee ready
Thank you very much for your kind help!
Xiaogang
08-17-2005 07:08 AM
You can use NI VISA for communicating using serial port.
08-17-2005 08:36 AM
There are some vi's that should work for you for the parallel port. However it has been communicated that with windows after 98 it's a little bit more complex...
I add a llb I downloaded from this forum a while ago that should perfectly fit your need (if you get it to work 🙂
08-17-2005 09:51 AM
Hi Xiaogang,
it's nice to see, that somebody distributes my "old stuff" ..... see attachment from Henrik Volkers..................
Find attached a vi... that fits much better to your needs - made for ANALOG DEVICES AD5207,
a two channel - digital potentiometer (written in LabVIEW 7.1.1). You simply need to adapt this to your needs.
In case you have still questions - let me know ........... or ask the Henrik - the distributing Expert.
Have a nice day
Werner
08-17-2005 11:11 AM
08-18-2005 08:43 AM
Werner ,
I thought of searching the board for your article to post a reference, but it was faster to dig in my drive.
All stars belong to you *****
Especially because this vi includes a wonderful way of documentation.
Thanks for the update.
BTW: Did you wrote them for AD?
08-19-2005 02:23 AM
11-08-2007 07:24 PM
11-09-2007 03:46 PM
Hi ILLGG,
It looks like this is an old thread and you seem to have another forum thread open with the same question. Tom W has posted an example on this forum that should be able to help you with your application. Please try to keep all questions about your one application on one thread. Thank you again for posting!
10-11-2010 11:20 AM
In this project (AD5207.vi) I have seen that It's used a buffer 74HC573, how can I connect OE/ and LE inputs?
Can I use this project (AD5207.vi) to run a SPI communication for AD8402? In this case is it necessary to use the buffer 74HC573?
I want use this digital potentiometer as a rheostat, can I to verify the exact value of resistors (B1-W1 or B2-W2) using a simple tester?
Must the AD5207.vi run continuously or is it enough a single run to set a resistor's value?
Thanks.
Best regards
Fabio
