08-20-2015 02:34 PM
At this link http://zone.ni.com/reference/en-XX/help/371599L-01/lvfpgaconcepts/create_acq_clip/ it says "If you use IP defined using Verilog, you first need to compile this IP into a netlist file, then wrap the netlist file in a VHDL file."
I have this situation, but I don't know how to wrap the netlist file into VHDL file, anyone knows how to do this?
Michel
09-29-2015 07:44 AM
I finally found out how to do this. My collegue has developped a IP in Vivado which I needed to integrate into LabVIEW FPGA VI's. We are using Vivado 2014.04, so the netlist of the IP has a *.dcp extension. In the same directory you should find the component declaration which has a *.vho extension. You should use the information in that file to create the wrapper. The wrapper will have a *.vhd extension and will be used with the *.dcp to create your CLIP. Basically the wrapper creates an instance of the component.
I've inserted an example:
SelfResonatingCore.vho
SelfResonatingCoreWrapper.vhd
Michel
