How to write static clock and step function to HSDIO
I want to write a static clock to HSDIO, when running the code, the clock will run until I stop the code. Also, I want to create a step function, at the beginning, the signal is '0', and there is a transition after some time, the signal will be always '1' until I stop the code. Thank you.
(2,823 Views)
Have you considered doing this with scripting? This is a good resource for getting started:
http://www.ni.com/white-paper/7285/en/
I'm thinking you could do this with two waveforms. Something like this:
wfmA:
Clk 0 1
Step 0 0
wfmB:
Clk 0 1
Step 1 1
script ClkandStep
    repeat until scripttrigger0
        generate wfmA
    end repeat
repeat forever wfmB
end script
Just keep in mind that Clk would output at half the rate that you clock the output waveform at.
Dale S.
RF Systems Engineer - NI
(2,762 Views)
Thank you for your help.
(2,753 Views)
