Hysteresis
Basic Level Trigger Detection vi. Hysteresis
What is the hysteresis level? Is it a percentage a voltage level or what?
(6,895 Views)
signal in contains the signal in which to detect a trigger.
level specifies the threshold value signal in must cross before a trigger is detected. The default is 0.
hysteresis specifies the amount above or below level through which signal in must pass before a trigger level crossing is detected. The default is 0.
http://zone.ni.com/reference/en-XX/help/371361M-01/lvwave/basic_level_trigger_detect/
So basically once "Signa In" cross "level" trigger=True and it will remain True until "signal In" crosses "hysteresis".
=== Engineer Ambiguously ===
(6,873 Views)
In layman's terms if I wanted to trigger at 3.00V with a negative slope and had a hysteresis of .01, I would theoretically trigger somewhere between 3.00V and 2.99?
(6,863 Views)
Negitive slope? Do you want to trigger on -3.00 volts or triggir on the falling edge of a +3.00 volt pulse?
You will have to bear with me here as I have never used the trigger VI, but have used an ocillioscope to trigger on all sorts of crazy waveforms...
I would imagine that the trigger VI would operate the same as the triggering on a modern DSO.
(6,857 Views)
I have a falling voltage starting at 3.3v it crosses at 3.00. I want to trigger there.
(6,852 Views)
Accepted by RavensFan
Well I would set the trigger for 3.00 volts and trigger on the falling edge to begin with and work from there.
(6,843 Views)
I missed the falling edge selection on the VI. That seems to have locked it in.
(6,837 Views)
