I can't edit my table while it's running
Hello
I created a table as a control and I can't edit manually the rows and columns while it's running
How to edit this in the table settings?
(4,013 Views)
Right-click on the control and check "Editable Cells" in the context menu. Or maybe its Enabled state is "Disabled".
Paolo
(4,000 Views)
These options are already enabled and I still can't edit while VI is running
Is there anything else to be done?
(3,996 Views)
AFAIK, no. Can you post your vi? But please save it for a previous version (at least LV2021).
Paolo
(3,992 Views)
Yes, I put it attached
(3,981 Views)
Accepted by leandrofeder
This may be non-intuitive, but you cannot create new rows while manually editing the MCLB at runtime.
First, you need to add rows with property "Item Names" to be able to edit them.
Then you can even edit empty columns as soon as you are in an existing row.
Example (to allow the editing of the 2 first rows):
P.S.: To edit a cell, you have to click it twice slowly (not double-click).
Raphaël.
(3,971 Views)
