I couldn't understand what this vi consists
Accepted by topic author bahadirozan
You can resize index array for multiple outputs. Just grab the bottom edge and drag down. If you want the elements in order, you don't even need to wire the indices.
You also circled array diagram constants.
Once you have an enum (easiest to create in this case by right-clicking the terminal on the subVI and "create constant"), you are halfway there.
Now take that diagram constant and "right-click...change to array", then resize to the desired number of elements and move to the desired place on the diagram.
I recommend the learning resources listed at the top of the forum.
Message 11 of 12
(305 Views)
Ah Sir, Firstly I apologize to you, I guessed You were younger than me. I apologize to you too much. I respect your career. Thanks for help. I am appreciated it.
Message 12 of 12
(287 Views)
