I didn't find multisim connectivity toolkit in connectivity function palette.
I have installed 'ni LABVIEW multisim connectivity toolkit powered by beta', then also I didn't  find it in connectivity function palette. I have read above facts in the tutorial downloaded from ni website. The tutorial is attached herewith.
Looking forward for your response.
Thanking you
Best regards
Avinash
(3,127 Views)
Accepted by topic author pkbigboss@gmail.com
There is a possibility that the installation is successful, but you are unable to locate the APIs in Function Palette OR there could be something wrong with the installation itself.
Well to check if the Multisim Connectivity APIs are present:
-> Open a new/black LabVIEW VI >> go to Block Diagram and open Functions Palette.
-> now press "Space + Ctrl
-> search for say 'Multisim Connect.vi'
if search result shows this VI then you can see where exactly its located on the harddisk (from VI's property dialog) and then also probable location on Functions Palette can be determined.
There is another possibilty that whole 'Connectivity' palette is set as invisible. Even in that case you should be able to search Multisim APIs using above method.
Select Visible Palettes
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,118 Views)
Sir
Actually I m using labview 2012 version , thus I didn't find the solution in the way you suggested.
Waiting for your suggestion
thanking you
Avinash
(3,088 Views)
Even I'm using LabVIEW 2012...!!
Would you care to elaborate your statement...!!
(3,081 Views)
Sir, thanks a lot , it was helpful.
(3,045 Views)
Sir
I have installed 'multisim toolkit beta'. I want to connect my usb daq device to my PC but didn't find 'MY DAQ' option in ni component list. I.e. (place >>component>>ni component >> ????? )
Avinash
(3,017 Views)
