I have a problem in using "DAQassistant"
Hi,everyone.I am a new learner at labview and from China. When I use labview 2014 and DAQassistant with advantech USB4750 , it will show ´error-536805376·¢ÉúÓÚ ToErrorCluster.vi" and "Get unique temp file name failed." I have reinstalled labview and win7 serval times,but it still have the same problem(at first i work well,but at last it didnt work. Sorry for my english.and Happy new chinese year to all. labview.jpg
Message 1 of 8
(4,031 Views)
Well part of the problem is that DAQ Assistant doesn't support non-NI hardware.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,008 Views)
there should be a one DVD in your advantech product install it  then the advantech daq tool kit will be appear in your labview beside daqmx
you can see in image about the toolkit
Message 3 of 8
(3,987 Views)
Accepted by mojozhang
also some version of this toolkit have problem so try to use different version of that
Message 4 of 8
(3,970 Views)
thank u
Message 5 of 8
(3,949 Views)
Did you solve the problem? I meet the similar problem:
错误:536870907发生于ToErrorCluster.vi
可能原因:
The data buffer is null.
Could you give me some suggestions?
Thank you!
Message 6 of 8
(3,769 Views)
Problem not solved. Tried with all available drivers. but still facing the same problem
Message 7 of 8
(3,334 Views)
what is your Daq kind?
Message 8 of 8
(3,307 Views)
