I'm tring to communicate with my S7-1200 PLC but it give protocol error.
Certified LabVIEW Developer
Message 1 of 8
(12,948 Views)
NI OPC server gives these protocol errors when i try to read bytes from PLC.
Date Time Level Source Event
12.1.2015 12:10:13 Warning Siemens TCP/IP Ethernet Unable to read 1 bytes starting at offset 30 for Memory Type M (e.g. M30) on device 'PLC_com.PLC-S7-1215c'. Device returned protocol error [Class=0x81, Code=0x04].
12.1.2015 12:10:13 Warning Siemens TCP/IP Ethernet Unable to read 1 bytes starting at offset 8 for Memory Type Q (e.g. Q8) on device 'PLC_com.PLC-S7-1215c'. Device returned protocol error [Class=0x81, Code=0x04].
12.1.2015 12:10:13 Warning Siemens TCP/IP Ethernet Unable to read 2 bytes starting at offset 0 for Data Block DB1 (e.g. DB1,B0) on device 'PLC_com.PLC-S7-1215c'. Device returned protocol error [Class=0x81, Code=0x04].
what is the reason of this problem? Can anyone help me?
Message 2 of 8
(12,926 Views)
Accepted by Onuralp
I found the solution. You need to check the "permit access with PUT/GET communication from remote partner (PLC, HMI, OPC, ...)". After that i compiled the project and accessed to the PLC.
Message 3 of 8
(12,898 Views)
You must configure the FB14 (GET) and FB15 (PUT) in TIA PORTAL ?
Thanks in advance for your answer.
Message 4 of 8
(11,962 Views)
Since this is an older post, it would be useful to have more information about your situation. What errors are you seeing? Are you using the exact same hardware?
I would actually recommend creating a new post so that it will get more visibility.
Have a good one!
Matt G.
Product Manager
Message 5 of 8
(11,945 Views)
Thank you very much for your reply, It helped solving my issue
Message 6 of 8
(10,102 Views)
You need to check the "permit access with PUT/GET communication from remote partner (PLC, HMI, OPC,)
Message 7 of 8
(8,143 Views)
Thanks master!!!!
Message 8 of 8
(4,132 Views)
