I want to change language of installed LabView from German to English without loosing all settings and data.
Is it possible to change language of installed LabView from German to English without loosing all settings and data?
Labview version : 11.0 (32 bit).
(3,425 Views)
Most of the settings are saved in LabVEIW.ini file, which is created by the LabVIEW.exe and is placed next to this exe.
You may want to copy this INI file and can restore most of the user configurable settings even after installing a different version.
This is just my assumption, however I've never tried this.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,402 Views)
I make copies of my LabVIEW.ini file all the time.  I have set configurations for each of my installs.  So when I do a fresh install, I just copy my ini file over top of the default ini file.  And I instantly have all of my settings.  No need to play around inside of the Options dialog.
GCentral
(3,393 Views)
