I want to compare two arrays and output one boolean
This should be simple.  I want to compare two arrays (5 elements each) and return a single boolean (T/F), not a boolean array.
Kevin
(3,284 Views)
Accepted by atomless
Right click the comparison, Comparison mode, select Compare Aggregates.
(3,282 Views)
(You still seem to have the problem that you are confusing controls and indicators, making it necessary to use locals. Using an indicator as a control is not a good idea, because it cannot be operated when the VI is in run mode. You can easily switch the behavior of any control/indicator by "right-clicking... change to control/indicator").
Ravens suggestion is good, but there are other possible answers because you did not tell us what the single boolean should show, e.g.:
  • Are all elements equal?
  • Is at least one element equal?
  • Are the arrays of equal lenght?
  • etc.
(3,275 Views)
