IMAQdx: License not activated Error
Hi All,
I am trying run my vision program executable which uses IMAQdx vi's, but every time I try to run the program I get error saying " NI-IMAQdx : Licensed not activated" whereas when i go to License manager, all the product labview and vision developmental run time module is green and activated.
Please let me know what can be the issue. I also tried uninstalling and installing and activating run time and imaq dx driver again.
Can anybody tell whats the problem.?
(7,348 Views)
Accepted by AnkitG
Hello AnkitG,
Do you have the LabVIEW development environment (and the VDM) as well as the VDM run-time installed and activated on the same computer?  As per this KnowledgeBase, this configuration won't work:
KnowledgeBase 69C9G5QO: Why Do I Get an Invalid License Error When Using NI Vision Development Module Run-Time Engine and NI Vision Development Module on the Same Machine?
http://digital.ni.com/public.nsf/allkb/B2C7256D8F31290186257B6A0050AB0A
The reason for this is also described at the bottom of this article:
KnowledgeBase 2HUBJPXL: Licensing National Instruments Vision Software
http://digital.ni.com/public.nsf/allkb/F1699570F78FECBB86256B5200665134?OpenDocument
Tom L.
(7,329 Views)
@0utlaw wrote:
Hello AnkitG,
Thank you outlaw, It was useful information, I didinot activated the Vision acquisition software I will try activating that and check again.
Thanks.
(7,300 Views)
Do you have solve this problem, I also have this problem and I dont know how to solve it.If possible ,please help me and contact me with email 740126966@qq.com .Thank you very much & Best Wishes.
(7,129 Views)
I was able to solve this, I had virtual machine running on my machine which was changing my Ip adress. Once disabled that I was able to activate the require software.
(7,113 Views)
