10-20-2011 09:43 AM
Hi!
Could you tell me, what is IMAQdx.rc file? and what is used for?
Thank you!
10-20-2011 09:52 AM
It defines the IMAQdx resource definition. Basically it is a hierarchical format that defines the IMAQdx class and defines the properties and methods you can use in LabVIEW on that class. You should not attempt to edit or move this file at all. It's syntax is undocumented and private to LabVIEW.
10-20-2011 09:54 AM
Thank you very much! The reason is why I'm interested it about imaqdx.rc is, I've created a source distribution that contains some IMAQdx vis. In the distribution folder I've found this *.rc file, so I can not convert the folder to llb. Can I copy or move this *.rc file somewhere else or it must be palced next to IMAQdx vis?
Thanks in advance!
10-20-2011 09:57 AM - edited 10-20-2011 09:57 AM
It should reside in the <labview>/resource/objmgr directory and also stay there. LabVIEW VIs should not need it, only LabVIEW itself should. Which version of LabVIEW is this?
10-20-2011 10:19 AM
2009 sp1
06-09-2015 04:05 PM - edited 06-09-2015 04:07 PM
I have recently installed LabVIEW 2010 and I get an error when trying to run a VI file.
Once I try to open the VI file, it asks me to "Find the Control Named "IMAQdx.ctl" and once the VI loads it is broken and I recieve an error saying that "This VI needs a driver or toolkit that is not found. Missing resource file "imaqdx.rc".
Any ideas how I can resolve this issue?
Thanks a lot,
Sam
06-09-2015 04:20 PM
