IS CLIP supported by Xilinx Spartan3E driver for LabVIEW 8.6?
For HDL interface node, the enable chain and multi clock domain is difficult to understand:(
(3,085 Views)
Accepted by Byran van der Tang
New version of driver that supports CLIP is posted: ftp://ftp.ni.com/evaluation/academic/spartan.zip
First uninstall your current version and then install this one.
(3,064 Views)
Reidl,
Thank you for your answer.  How do I uninstall my current version?  I have looked in "Add or Remove Programs," but I don't see anything under "Xilinx" or "Spartan."  I do see an entry for "National Instruments Software."  However, when I click "Change / Remove" I don't see any entries for the Spartan Board.
I tried running the installation program, and I received the following message:
The NI LabVIEW FPGA Support for Spartan-3E 1.1.0 installation has failed with the following error.
You have a higher version of NI LabVIEW FPGA Support for Spartan-3E in your system.  You must uninstall it before installing this again.
What is the latest version number?  How do I check what version I currently have?
James Carroll
(2,982 Views)
In Add/Remove programs, you should see a National Instruments Software section.  Click Add/Remove on that.  Then in the next dialog, you should see an entry for LabVIEW FPGA Support for Spartan-3E (or something similar to that).  Remove that first, then install the copy I've posted to get CLIP support.
reid
(2,970 Views)
Reid,
Thanks.  I found it and successfully installed the other driver.
James
Message Edited by jcarroll on 03-30-2009 11:28 AM
(2,909 Views)
