Icon Library xml went astray
So did anyone else realize there is an NI Icon Library Update Tool?  What is wrong with the one built into the icon editor?  Other than it doesn't work.  I'm a little annoyed that you need another tool because the first tool doesn't work.  Funny thing is after installing it I was prompted with our familiar dialog telling me it couldn't contact NI's site and to install the library manually...so now I have two ways to not update my icon library.
Message 11 of 13
(520 Views)
It probably uses the same code as the tool in the icon editor.  And somebody probably moved the exact location of the xml and zip files on the server and didn't update it in the code.  Therefore, fail to connect.
GCentral
Message 12 of 13
(514 Views)
Apparently this problem has been occuring since LV9 and still isn't fixed yet?
It seems like it should be a quick fix, but remains broken?
Here's the other thread I found to work:
http://forums.ni.com/t5/LabVIEW/Glyph-Library/m-p/1003863/highlight/false#M448340
Message 13 of 13
(449 Views)
