Ignore first value of real time data
I am trying to remove the first value of real time data without it going into an array. I have tried using variables and some maths to ingore it but i havent got it to work.
If you have any ideas please let me know.
I have attached a file of an exmple but also a snapshot of what i am trying to do.
Any help would be useful.
(4,545 Views)
Hi zandrous,
implement a case structure: "IF not(first iteration) THEN put value into array"…
(4,526 Views)
Hi GerdW
thanks for your quick response, how do you define the first iteration if you do not know its value?
i am new to LabView so i apologise if this seems mediocre
(4,521 Views)
Accepted by zandrous
Hi zandrous,
in each loop you will find the loop iterator: a small rectangle with an "i" inside. This one counts the loop iterations - and it starts with zero.
So when "i == 0" then "it's the first iteration of the loop"…
(4,517 Views)
I don't remember where Conditional Tunnels were introduced (I think 2012 or 2013), but here's how to do this with such a tunnel.
Normally, the While loop would build an array of all the Random Numbers you were generating.  However, the Conditional terminal, initialized to False (and reset to True for every iteration except the first) prevents the first number from being included in the Indexed array output.
The Conditional Indexed tunnel simplifies (a lot) the selective "building" of arrays from within a loop.
(4,506 Views)
