Image Reconstruction
I'm trying to reconstruct a sinogram image to 2-D sclice CT image. Don't known how to implemented this in Labview
Detail info. of the sinogram data : Array size 767 X 360(Projection)
I'm using LV 8.6 & IMAQ.
Can anyone give suggestion?
Lojius Lombigit
Malaysia
email: lojius@nuclearmalaysia.gov.my
Message 1 of 8
(7,300 Views)
Can you explain it with more details?
Message 2 of 8
(7,292 Views)
I'm using linear array Detector with fan beam Xray source, data capture via framegrabber card and the raw data (I16) 2-D array of 767 (ray sum) X 360 (Degree of projections).
I manage to display the sinogram with by using IMAQ array to image.vi.
Now i'm trying to reconctruct tomography image from the sinogram. Do some research and find that method called filtered backprojection are commonly used for image reconstruction.
Can this method implemented in Labvie?
Message 3 of 8
(7,287 Views)
Message 4 of 8
(7,282 Views)
Message 5 of 8
(7,278 Views)
Thanks for the suggestion. Unfotunately our institute did not have access to the journal
Message 6 of 8
(7,273 Views)
Its not extremely complicated. You should propagate each row to the whole image, then rotate it and continuously add results:
But normally you will get some reconstruction artifacts, and avoiding them may be tricky...
Demo project in attachment.
Good luck!
Andrey.
Message 7 of 8
(7,257 Views)
Accepted by lojius
Thanks a lot. This is very helpfull indeed.
Message 8 of 8
(7,221 Views)
