Importing a picture without background to the front panel
Dragging or importing a PNG should allow you to resize it. If the size of the image is large, you sometimes can't see its edges and need to scroll to them, but you should still be able to find them and resize.
Alternatively, you can resize the image in Paint.NET and then import it (something which I personally prefer, since LV's scaling algorithms sometimes have aliasing issues. You can see some discussion about this here - http://forums.ni.com/t5/LabVIEW/Scaling-a-JPEG-with-ZoomFactor-Property/td-p/483555).
___________________
Try to take over the world!
Message 11 of 19
(1,626 Views)
Mani.World & tst -
The file is already a .png file, saved in Paint.NET with the transparency removed. I used the magic wand tool to select the background and delete it. I also experimented with an "Alpha Mask" plug, no help. When I import the file in LabVIEW, it shows up with a transparent background. Great, but I can't resize the image. Where copy/paste brings in a white background, but the resize does work.
I did scroll all the way to the edges of the image to find the handles to resize it - they are not there with the import method. I also tried the set width and height tool, but it doesn't change the size either.
I understand the advantages of resizing in Paint.NET, but it's time consuming compared to resizing in LabVIEW - I'm copying simple line drawings where image quality is not a problem.
Thanks for the ideas...
Message 12 of 19
(1,605 Views)
Can you upload a sample pic. That way, I can take a look at it and suggest a solution to you.
Cheers!
Message 13 of 19
(1,594 Views)
Sure,
See the attached file - thanks for looking.
Message 14 of 19
(1,575 Views)
When I drag this image into a front panel in 2011, I get the resize handles and the resize dialog works as well (note that you have to click apply). The resize handles are a bit far from the actual graphic because the image has white space in it, but they're still there at the edges of the actual image.
Resizing it in LV also causes a lot of detail to be lost - LV's algorithm problems is particularly noticable with line drawings.
___________________
Message 15 of 19
(1,560 Views)
Please see the attached vi. I've dragged your .png file into LV Front panel and resized it using the resize handles. You image is quite big (>1500 pixels WxH) so the resize handles don't sometimes show on the visible screen. However, you should be able to them now in the attached VI once you click on the image or just hover the mouse over it.
For line drawings, I'd suggest scalable formats like metafiles since you don't loose the details that much and reducde the original picture size (draw on a smaller scale, keeping in mind the VI screen size in pixels)
Hope this helps
Cheers!!
Kudos are the way to go!!!
Message 16 of 19
(1,549 Views)
I wasn't able to paste (PNG image) with transparent background by using Ctrl-V. instead, as suggested by TechWiz in an earlier post in this thread, I dragged/dropped; this worked.
Message 17 of 19
(1,365 Views)
Message 18 of 19
(1,353 Views)
Please give/use kudos if any post is helpful to you.
Message 19 of 19
(1,329 Views)
