Importing waveform graph into a standard report using advance report generation toolkit
I have been trying to import a waveform graph into a standard report using advance report generation toolkit which I am able to import in the form of a .jpg or .png format.
But then is there any other means through which I can directly import these waveforms into the report other than the image formats?
I have shared the front panel and the block diagram images in the attachment.
Thanks in advance...
(2,478 Views)
"I want to get help on my LabVIEW Code from the LabVIEW Forums.  I'm appending my LabVIEW Code as Pictures, which I (should) know will annoy the Forum readers who might want to examine my code closely, maybe even try it out, and might want to experiment with "fixes".
The above paragraph is my analogy to your Post and attachments.  Please attach the actual VIs that you are describing.  It is much easier to read and understand a full-size diagram, plus we can test it, edit it, and examine its behavior (not to mention seeing "behind" Case statements and other hidden items).
(2,442 Views)
