Impossible to modify the value of cells while the VI is running
I'm trying to change the table values while the VI is on, but without success, someone can show me please how to do this.
MGarry
Message 1 of 13
(2,630 Views)
Spoiler
You are not reading from the table at all!
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 13
(2,620 Views)
In fact aCe i'm reading from the table in another VI, the values are transfered from it to an Excel file and i want to allow some flexibility to the programme by making changes after reading and saving them. If i can change the values in the LV table i can do the same with the excel file.
Thanks for your reply.
MGarry
Message 3 of 13
(2,606 Views)
MGarry,
you are writing new values into the table every 6 seconds. So, if you made any changes, they will be overwritten because the data you write to the table is held in the shift register.
So instead of using a shift register, you can read from the table itself, add new stuff and write back using the local variable as you do right now. This is one of the rare cases, where a shift register might not be suitable for the task.
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(2,601 Views)
Ok Norbert, so how would i be able to perform the continuous reading if there is not any shift register, what do i have to add ?
MGarry
Message 5 of 13
(2,596 Views)
Put the table terminal into the loop and read from that instead of the shift register. Delete the shift register (and connected wires) but keep the writing local variable referring the table.
Norbert
Norbert
Expert: Geometry
Message 6 of 13
(2,593 Views)
I can't make it work this way maybe there is something i'm missing or doing badly, please if you could modify the VI i posted that'll be nice.
MGarry
Message 7 of 13
(2,589 Views)
Accepted by topic author MGarry
MGarry,
something like this:
Please note that this does not reset the table content if you rerun the VI. You might want to add some code for that.
Norbert
Norbert
Expert: Geometry
Message 8 of 13
(2,584 Views)
Thanks Norbert this is working,
MGarry
Message 9 of 13
(2,574 Views)
there is something else, after doing the changes, i'm trying to modify directly from the Excel file and it seems to be impossible, i guess in order to do that Labview should be able to read from the Excel file while it's writing to it, can this be done ?
MGarry
Message 10 of 13
(2,569 Views)
