In labview if i select any one elements in the drop down box, the page corresponding elements need to change
like an example of
If i select first element in drop -down box, In the page it should display only numeric control 1 and 2
If i select second element in drop -down box, In the page it should display only numeric control 3 and 4
If i select third element in drop -down box, In the page it should display only numeric control 5 and 6
because i really new to the labview.
any answers thanks.
with regards and warm welcome,
Ramamoorthy S
Message 1 of 13
(3,273 Views)
Something like the attached one?
Mathan
Message 2 of 13
(3,265 Views)
As Mathan given you can use a seperate Enum to change the page or else you can use the Page Label Display option (Right lick Tab>>Visible Item>>Page Label Display) to change the Page. Its always good to go through the Basic Materials (Available here and here).
Message 3 of 13
(3,263 Views)
in the same tab page that drop down box should be there and when we select the element in drop down box, Numeric controls should change.
Ramamoorthy S
Message 4 of 13
(3,246 Views)
So if I get it right you actually want everything on one page? You could try using property nodes... see example.
Message 5 of 13
(3,242 Views)
Did you go through the materials that I have pointed out? I would suggest you try on your own since these are very basic things and come back if you face any trouble.
Good luck
Message 6 of 13
(3,241 Views)
Can you please post the vi in LV 2009?
Message 7 of 13
(3,238 Views)
You can still use Mathan's approach (or my approach) by making the tab control transperant, since it is straight forward you can go without playing around with the property nodes. Check the attached vi.
Message 9 of 13
(3,227 Views)
And, just because I hate tabs, You can chek out this pseudo tab that uses subpanels to display and act on different groups of controls in message 15 of this thread
"Should be" isn't "Is" -Jay
Message 10 of 13
(3,223 Views)
