Increase UDP received packets per second
Hi Marcus,
Sorry for being so long to reply.
Thank you for your great job.
In order to consolidate a complete source code, would be possible that you also post the C project in the same way jjjcjj did before ?
Sébastien
Message 31 of 37
(1,411 Views)
Hi jjjcjj,
Do you remember what you did exactly for these two points :
- does correctly have timeouts
- has much much better performance (i was forgetting to set the winpcap buffer size... oops) : seems default buffer size is OK... Or maybe you thought about the registry key you mentioned earlier ?
Message 32 of 37
(1,382 Views)
Here it is:
Message 33 of 37
(1,355 Views)
That's perfect, thank you
Message 34 of 37
(1,332 Views)
I can't see the project because I don't have LV 2019 installed, but if it's the example I'm thinking of, be aware that it is intended to be used as a standalone application and doesn't output any errors.
Bill
CLD
(Mid-Level minion.)
Message 35 of 37
(1,317 Views)
Hi!
On the LabView page I did not modify that much, but of course I don't give any warranty on anything 😉
BR
Marcus
Message 36 of 37
(1,304 Views)
@marcuskr wrote:
Hi!
BR
Marcus
Don't get me wrong.  I'm not saying it's bad programming at all.  I'm just saying it doesn't expect to get called, so it doesn't report any errors.  It may give you a visual indication, which is fine for a standalone, that's all I'm saying.  🙂
Bill
CLD
(Mid-Level minion.)
Message 37 of 37
(1,292 Views)
