Index the output of a stacked sequence
Hi everyone,
I'm writing some code in which I instantiate many objects when I first start my code and place the objects into an array that is used as a lookup table later on in operation.  This takes up a lot of space on the block diagram and makes it difficult to understand for the user that is not familiar with the code.  Is it possible to create something like a flat sequence that can have a single indexed output tunnel?  I want something like what you would get when having a tunnel out of a for loop I just want each itteration to be unique (unlike the for loop).  I've included an image of what my diagram currently looks like for reference.  You can see that I create all of the objects with unique information (ID, control reference, etc.) and then build an array with them.  I would like to instantiate each of these objects in a frame of a stacked sequence with a single indexed output (if possible).  objects.PNG
Thanks for the advice!
-Eric
(2,965 Views)
You could make that whole thing there a sub-vi.  That way it is nice and clean at a higher level, but if you needed to look at the nuts and bolts, nothing is hidden...
Bill
CLD
(Mid-Level minion.)
(2,958 Views)
Accepted by etridas
Option 1: use a subVI
Option 2: Use a FOR loop as a sequencer.  Instead of the stacked (or flat) sequence structure, put a case structure inside of a FOR loop and wire the i to the case selector.  Then in each case you can initialize a different class.  The output can then be autoindexed.
GCentral
(2,954 Views)
I had considered a sub vi but if you notice i have control references as inputs and so I would still end up having to create a cluster of references as an input to the sub vi.  I really like the idea of the for loop and the case structure.  I don't know if its really proper to do that but it will definitely clean up my code a lot.  Thanks.
-Eric
(2,950 Views)
-Eric
I actually like option 2 better, also.  That's why cross has all those logos.  😉
Bill
CLD
(Mid-Level minion.)
(2,945 Views)
