Input and Output State
Give an example how can I do this outside of loop because I added value 0 to some ports outside of loop and did same
Message 11 of 13
(211 Views)
Hi Chris,
You use DATAFLOW to execute code AFTER the loop has finished!
A simple way to ensure DATAFLOW (aka execution order) is to use the error wire…
Message 12 of 13
(204 Views)
Where is the error line? on stop button loop or 'i' on side of while loop?
Message 13 of 13
(192 Views)
