05-23-2022 09:19 PM
Hi all,
I can't seem to figure out the tunnelling - if that is the issue - to insert items at a given index in an array.
I've attached my example, where I initialise an array of all 0s and add some arbitrary elements at some points. The output is a different array for each element I wanted to insert. I just wanted to add them all to the same array.
Does anyone know how to do this? Any help would be greatly appreciated.
05-23-2022 10:23 PM - edited 05-23-2022 10:24 PM
Your initialized array needs to be in a shift register.
You should also use "replace array subset" instead of "insert into array". (Insert will add a new element, shifting all upper elements up and growing the array in size)
