Installing 32 bit version of LV20 on 64 Bit machine
Hello !
Can I install 32 bit version of LV20 after installing 64 bit version ?
Or should I uninstall the 64 Bit and start from scratch installing 32 bit first ?
Much appreciate an opinion.
(947 Views)
Hi nitishkati,
Yes.
Do you need "opinions" or do you need facts? 😄
(941 Views)
@nitishkati wrote:
Hello !
Although the usual path is 32-bit then 64-bit, I don't see a problem installing in reverse order.  I think you'll have to reinstall your NI drivers and toolkits to make them aware of the new install, though.
Bill
CLD
(Mid-Level minion.)
(884 Views)
You should be able to just go to the "Packages" section of NIPM and just install the "LabVIEW 2020 (32-bit) Support" package for each of the drivers needed.  Toolkits are probably included with the LabVIEW install.
GCentral
(877 Views)
OMG - my advice is so 2016!  😅
Bill
CLD
(Mid-Level minion.)
(872 Views)
