Installing NI-DAQmx in Windows XP x64
hello,
I've been trying to install NI-DAQmx in a computer with Windows XP x64. I've read some of the discussion news about this issue, yet I could not find any post that has a solution to it. May I know what should I do to get NI-DAQmx to be installed in OS XP x64? Thank you very much for your time and help.
(2,890 Views)
If you have read some of the posts, then this one should explain it all. There is no driver for XP 64 nor do I think it's likely that there ever will be one. I haven't even seen much support for this OS from Microsoft. It's all been about Vista.
(2,881 Views)
uh oh... that's certainly a bad news... so even NI-DAQmx 8.9 will not solve the problem?
(2,872 Views)
You can see the supported OS's.
(2,863 Views)
Alright... Thank you very much for your time and help.
(2,858 Views)
Sorry, there is no support for Windows XP x64.
Jeff | LabVIEW Software Engineer
(2,835 Views)
