11-01-2016 05:00 PM
I did that, thanks. I just thought I'd let you know something was up with the snippet. I got it working, sort of. I want to make the sound each time a key is clicked on the keyboard. 500 millisecond timeout seems long for a key stroke. Even set to 100 mSec is still too long of a delay for a keyboard feedback.
11-01-2016 08:19 PM - edited 11-01-2016 08:21 PM
Can anyone else reproduce the error. The snip was taken with the CCT. If reproducible,. LAVA needs a ping. Thanks
Again that is only proof of concept code the event I would trigger on in your application would be the value change event of any button that you want the beep to come out with
11-02-2016 12:19 AM
unfortunately ....yes
11-02-2016 02:01 AM
You can configure the Beep.vi to not be an Alert by setting that input false.
See if you can open this snippet:
I think it sounds a bit like an old typewriter (play with the settings).
steve
P.S. Jeff - I got the same error opening your LV: 14.0 Snippet
11-02-2016 08:56 AM - edited 11-02-2016 09:01 AM
@stevem181, yes I can load your snippet. Apparently something wrong with snippet from @Jeff·Þ·Bohrer.
@Bob_Schor also suggested the Beep.vi. It is certainly much quicker with very little noticeable delay. It behaves oddly though. Indeed, I tried it, even tried your snippet. When I turn off the 'use system alert?' it seems to work sometimes and other times, not (sound vs no sound)... keeping the freq and duration consistant (not changing it between tests). The help for beep says "This might not work correctly if 'use system alert?' is turned off"
11-02-2016 03:30 PM
I noticed the Beep help warning when I was playing around with it.
On my system it was flakey when I set the duration to 1 msec.
So I was thought the warning might be an issue with certain settings.
It's a strange warning. NI seems to know of an problem but does not give any details.
Looking back - in LabVIEW 2010 there was no warning - by 2012 there was.
steve
