Inverse of two's complement
Hi I am trying to convert a U32 two's complement number back to a negative integer.
Can someone guide me on this?
(486 Views)
Accepted by topic author Satvikpai
Hi Satvikpai,
An U32 is (as the name says) an UNSIGNED value, so it cannot be negative!
Maybe you want to convert the U32 value into an I32 value (using ToI32)?
(471 Views)
If you somehow got a signed integer stored in a U32 (read from a file to the wrong type?), you can use a type cast to convert it to I32:
(432 Views)
Hi JJohn,
ToI32 does the very same job - and (probably) more efficient and with less BD space…
(403 Views)
Thanks for the note onToI32.  I did not know how it would handle values with the sign bit set.  On a good day you learn something new.  Thanks!
(389 Views)
