Is it possible to express two y axes on a xy graph with different scale
I need to program it... Please help me
(3,278 Views)
I believe this feature is available for LV6.1 and above.
Go to the Y scale and right mouse click. Select DUPLICATE SCALE option.
Robert
(3,278 Views)
First, left click on the existing Y axis and select Duplicate Scale. Second, if you wish, right click on the new scale and select Swap Sides to move the new scale over to the right side of the graph. Third, in the plot legend, right click on the plot that you want ot associate with the new axis, choose Y Scale and then the name of the new axis.
(3,278 Views)
Hello.
Yes, it is possible to have two different vertical scales on an xy graph. There is no way that I know of to add a scale programmatically, but once you have added it, you can configure the range of it programmatically, as well as assigning a plot to any particular scale. You do this by using an xy-graph property node, with the properties YScale.Minimum, YScale.Minimum, and Plot.YScaleIndex respectively.
(3,278 Views)
Thank you so much...
I want it. Have a good day...
(3,278 Views)
