01-29-2020 09:59 PM - edited 01-29-2020 10:01 PM
Hi, I want to interface MPU6050 Gyroscope/Accelerometr module using ELVIS or MyDAQ. Is it possible to interface? Because MPU6050 has I2C/I/O (SCL/SDA), but in ELVIS or myDAQ there is no such inputs only digital inputs and outputs. So is there any way to interface through digital I/O? If yes, then please guide me how physically i can connect and in Labview.
Thank you.
01-29-2020 10:10 PM
There are USB devices/chips that can "talk" I³C or SPI. Use one of them to communicate with your MPU unit. NI makes one that includes a LabVIEW driver, but I've seen others that "look like" a Serial Device (though very fast) sending SPI commands through VISA.
01-29-2020 10:17 PM
Thank you for your kind reply. Yes i know about this but i have to use ELVIS or myDAQ. One of these to interface.
01-29-2020 10:38 PM
Since your Chip only talks through SPI or I²C, which are special serial protocols that run on fairly fast clock rates that I don't think either the ELVIS nor myDAQ can support, then you are doomed to failure. You need hardware capable of supporting the protocols that your chip requires ...
01-29-2020 10:39 PM
Ok, thank you so much 🙂
