Is it possible to pass a signal from an input to a signal output with out doing anything
Hi all,
I am using a DAQ card 6601
I would like to take a simple digital signal input and pass it straight to an output, untill I recieve a different input at which point I want to send my own signal to the output port.
I have have a small program which reads a signal and then sends out a signal at the correct times the bit I am stuck with is just sending the input of one terminal to the output of another terminal with out changing any thing.
Thank you
(2,862 Views)
Hi Dowden1,
what do you mean with another "terminal"? Do you have more than one DAQ card? Can you show what you have so far?
Mike
(2,851 Views)
Accepted by topic author Dowden1
Since doing a write of what was just read is nothing more than this :Read then Write.PNG , you are going to have to explain what you are having a problem with.
(2,844 Views)
Hi Dennis,
Thank you, I am having one of those days! Now you show it, its very easy and I feel quite stupid, thank you for your help
(2,837 Views)
