Is it possible to prorammatically move a control out of a case structre
@Seau1 wrote:
Thank you very much for the help, I will try your solution as fast a possible. I need this because I have to fix a VI Generator which saves the controls and indicators inside of diagramms.
Isn't it better to fix the generator so controls are created outside? 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 16
(624 Views)
I was also thinking about it but I think that is way more complicated in this case and I'm not sure if it is possible. Well I'm not a LabView expert so I could be wrong
Message 12 of 16
(616 Views)
Just like with the Move-block, the Create VI Object have an 'owner' input. That just needs to be the top level diagram instead of a while loop. 🙂
Qestit Systems
Message 13 of 16
(614 Views)
Well we use an existing VI as template to create the VI with complicated code and I'm not a fan of changing another persons code when I'm not sure what it is exactly doing.
Message 14 of 16
(601 Views)
What's the worst thing that can happen? 😉
(Famous last words)
Qestit Systems
Message 15 of 16
(595 Views)
So... You're changing it with scripting because you don't want to change it manually because you don't know what it is doing?
Saying it like that (and that is how we read it) it is quite funny.😁
BTW. By now this might read as a personal attack, but we're just curious... Please remember we only get to see a small peace of the puzzle, and (humorous) tone gets lost over text. I'm sure you have good reasons, you don't have to justify yourself if you don't want to,  it's absolutelly none of our business, etc., etc..
Message 16 of 16
(594 Views)
