Is it possible to sort my second array according to the first array sorting order ?
I have 2 array,
1st array contains number 1 to 9 in a random order ,
2nd array contains random number,
I want to : sort array1 , then sort array2 according to array 1 sorting order , for example:
array1 : 1,2,3,4,5,6,8,9,7
array2 : 464,353,345,456,567,678,88,99,77
after sorting (element 9 become 7, 8 become 9, 7 become 8):
array1 : 1,2,3,4,5,6,7,8,9
array2 : 464,353,345,456,567,678,77,88,99
(1,842 Views)
Accepted by PULSE.Wannabe
Yes, that's easily possible. What have you tried?
(1,832 Views)
(1,829 Views)
ah I never use index and bundle cluster array, I didn't concatenate them because I thought it will also sort the 2nd array.
thanks !
(1,733 Views)
Arrays of cluster will sort by cluster order. The values of the second element are only relevant where there are duplicates in the first value.
(1,728 Views)
got it , thanks so much !
(1,690 Views)
I made a set of Array manipulation code posted over on VIPM.IO which supports many additional function as VIMs so that the data types can transform as needed.  One of the functions I named the Foreign Key Sort, which sorts one array based on another.  Under the hood it basically does what others have suggested here, but it does return other optional things such as the pointers (indexes) of how the rearrange went.
(1,638 Views)
