Is there a way to convert 8 Rows by 2 Columns to 2 Rows by 8 Columns?
I have tried but came to an stop...
How do I convert 8 Rows by 2 Columns to 2 Rows by 8 Columns?
as shown in the vi attached
Thank you very much...
(3,854 Views)
Hi Diego2000,
Trying using the Transpose 2D array function found in the Array functions palette, think it is what you are asking for.
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(3,849 Views)
Accepted by topic author Diego2000
@JohnMc19 wrote:
Hi Diego2000,
No, for the required transformation reshape array is required, not transpose.
Compare:
Andrey.
(3,840 Views)
Thank you Andrey:
I believe that will work.
So, if my array is of a longer size, I'll just enclose it
in a while loop, right?
thanks again...
(3,778 Views)
@Diego2000 wrote:
So, if my array is of a longer size, I'll just enclose it in a while loop, right?
No, it doesn't matter which size you have (the only memory is your limit). Just get dimensions programmatically and reshape it:
Andrey.
(3,772 Views)
