Is there a way to detect mouse over event for controls inside a tab control?
I need to change the mouse pointer as it moves over controls which are located in tabs.
Now when the mouse moves over to the tab, LABVIEW does not detect the controls saperately for mouse over event.
Is there a way to do what I intend to do?
Message 1 of 8
(5,636 Views)
I'd like to see your code because we do this exact  thing.  Specifically, we use the Mouse Enter and Mouse Leave events to change the mouse pointer depending on what it is over.
GCentral
Message 2 of 8
(5,629 Views)
What are you doing in your code? You can statically register for the mouse enter / mouse leave event on individual controls, and you can get a reference to all of the controls on each page of the tab control to dynamically register the events, so it's definitely possible.
(pardon the overlaps - it loses the link to the control when creating a snippet)
(blog)
Message 3 of 8
(5,625 Views)
Use the Code Capture Tool.  It doesn't break links the way the built-in VI snippet tool does.
Message 4 of 8
(5,585 Views)
You should also be able to get a reference to the control by right clicking on it and selecting Create Reference.
Mike...
PS: best solution would involve losing the tab control.
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 8
(5,554 Views)
Here's the part where I do the pointer changing. I tried to remove the Tab reference from the array of control references but that also did not work.
Message 6 of 8
(5,539 Views)
Accepted by zomboy_
Your problem is with the Panel.Controls[] property. It does not return controls which are inside containers (arrays, tabs, clusters) and only returns the container itself. As Sam showed, if you want the references of the controls in the tab, you need to get the references of the pages and get the controls in each page and add those to your original array and do this recursively.
You can either write a VI to do this (or look it up. There have been VIs posted here which recursively parse the FP for all control references) or just do it statically for this one tab control and move on. There's also a VI shipping with LV which can help with this, but I suggest you not use it, as it will be tricky to get it to work if you build an EXE.
And I would also recommend the Code Capture Tool.
___________________
Try to take over the world!
Message 7 of 8
(5,517 Views)
This works like a charm. Thanks!
Message 8 of 8
(5,504 Views)
