Is there a way to send the data from labview to vector canoe can bus?
what is the use of integrating vector CANoe and labview and i have shared data between CANoe using shared variables is there any other things like send data to bus or any other things we can perform?
(1,343 Views)
Using the shared variable, you can control the CANoe software to send CAN frame from Vector hardware from LabVIEW.
NI has its own automotive network devices known as NI-XNET CAN, LIN, and FlexRay Platform. They are natively supported in LabVIEW via the NI-XNET driver.
Control Lead | Intelline Inc
(1,335 Views)
Why we have to integrate Vector CANoe and Labview?
(1,318 Views)
How to access environment variable in Vector Canoe using Labview. I have seen we can do it using activex library but i  don't have idea on activex library and how to setup it. Can anyone help in this please?
(1,315 Views)
Or you can get the Vector CanLib driver for LabVIEW here: https://forums.ni.com/t5/Example-Code/Vector-XL-Driver-LabVIEW-wrappers/ta-p/3524976
Rolf Kalbermatter
My Blog
(1,288 Views)
