Is there a way to turn off and on trend lines while still collecting data in the chart history.
I can use a relay to turn the signal off and on, but it leaves gaps in the trend line when turned back on.
(2,234 Views)
Replace the trend data with NaN and it will not show the on graph until the values are again normal.
Can you show is your VI or at least a picture so we can see what you are talking about, thanks!
(2,233 Views)
